Results 1 to 3 of 3
Thread: Can I fit a VR [IRS] Fuel Tank into a VP [Non-IRS], is this do-able?
    VP Exec / VS Berlina
    Aug 2010
    NZ
    Question Can I fit a VR [IRS] Fuel Tank into a VP [Non-IRS], is this do-able?
    Hi there,
    I have a VP Executive V6 and under the car the Fuel Tank is munted, previous owner must have backed over a tree stump or something as its all pushed it... runs fine though the car that is..
    I have a VR Calais V6 that has IRS and the tank is mint on it, are these tanks the same? Can i simply remove it from my VR, and mount into my VP?
    If anyone can help with this, it will be much appreciated.
    Regards
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    my solid axle vr has the larger tank out of a irs car.....had to mod one strap for it to fit but the rest was exactly the same
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Markovr is on the money. irs cars have one strap that sits into a hole in the floorpan rather than bolting the car like in a solid diff car.
    all you need to do is cut both up and stick a bolt through so its longer and reaches/holds the tank up. easily done.
  1. Fuel Tank,Fuel Pump Assembly and Swirl Pot.
    By Brett_jjj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2011, 10:12 PM
  2. have had to wack the fuel tank to start my car!! is my fuel pump stuffed?
    By CV6Z in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-08-2010, 04:13 PM
  3. [VIC] Fuel tank & reco fuel injectors
    By BT1-355 in forum Parts And Other Items For Sale
    Last Post: 25-11-2009, 03:36 PM
  4. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  5. Very bad fuel odors and presure in fuel tank
    By Helicopter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2008, 01:29 PM
Tags for this Thread
