just wondering if any one has fitted vt v6 thermos or if its possibly on a vn 5ltr and if the standard altenatle will handel au twin thermos?
10 liters of aussie v8 cant go wrong
i have a vp 5ltr and twin au's best investment u could make ..... when u take the clutch fan off tho u will need to shorten the bolts or put a spacer in or buy shorter ones... coz they is too long buy 2-3mm.... other than that i have no issues with power - and i run twin 12 inch subs and amps etc.... u will have to hook up a temp switch so the thermos know when to come on - i bought one from jaycar for like 20 bucks or something - set the temp and away u go --
cheers mate i do have a 16inch fan but it dosent work that well lol is it easy to wire up? also my old clutch is tight to move with my hand is that good or bad?
the clutch fanb is connected to the crank so yeh should be on the difficult side to spin - least i havent had one for so long so dont think it free spins easlily..... umm yeh easy as to wire up if u buy a thermostat kit from jaycar or off ebay instructions are easy -
