Hi all, i am doing a vr v8 to series 1 v6 conversion.
Have got everything done. When i kicked it over the oil light doesnt go out.
Just want to know if the oil sender is faulty if i disconnect it should the ecu turn the mil light on if there is no oil pressure?
Cheers Shane
heres my ride, i know its not much but its mine
http://forums.justcommodores.com.au/...-ss-crewy.html
and heres my new project
http://forums.justcommodores.com.au/...ml#post1104629
theres no error coding for oil pressure it doesnt even feed into the ecu best bet is fit a guage even if only tempory to make sure it has oil pressure
thanks delco, i tried a pressure switch from a ecotech but still had the light so i am just trying to bleed the pump through the pressure switch hole. i dont know how long the motor has been sitting for.
cheers shane
yeah i would do the same and put a guage in it
If the oil pump and pickup have been drained of oil, you must manually prime them before starting the engine or you will have zero oil pressure or circulation!
