Results 1 to 8 of 8
Thread: VN Commodore
    VN Commodore Executive 3.8LT V6
    Aug 2010
    Default VN Commodore
    I have a 1990 VN Commodore Sedan and it barely makes any noise and i want some grunt and noise. any ideas there? thanks
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    extractors and a 2.5inch cat back exhaust will get you lil bit more of a note..
    Signature Goes Here
    Aug 2010
    Nimbus 2000
    Sep 2008
    Hogwarts
    depends on how much you wanna spend on it,, as mine sits right now its got CAI, 2.5inch exhaust an will soon have extractors,, if you do put a high flow cat on you may want to get a ressie as well cos it can be a lil loud in some cases an the ressie will take out the harshness...
    Signature Goes Here
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    Quick mods, remove your restrictor if its still there, and get a cai(if there made for vn/vp's)
    manual vn commodor . turbo might be cool
    Jan 2010
    in the yarra valley
    replase the motor and gear box .... new motor should be a ls3 and a 6 speed gear box with a supercharger and mini spool..... the note will come with the ls3
    VP Berlina LX
    Jul 2010
    If noise is all your after, get the back muffler cut off and replaced with a 3 inch pipe. But dont expect the noise to be pleasant.
    drrrrroooooooooooooooooooooooooonnnneeee
    Replacing the rear muffler with a resonator/ "hotdog" might be a cheapish way to make a nicer note, otherwise, going up in price, would be a catback system, high flow cat (or none if that way inclined), then a good set of headers.
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    i did the same as what alex says on my old V6 back in the silly poor student days. i got compliments on the sound, even from mechanics
  1. will a vx commodore ecu work in a vt commodore
    By lestat2220 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2010, 10:05 PM
  2. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
