Results 1 to 9 of 9
Thread: how hard is it to fit a calias climate control into a vp spac
    1993 yota 4 runner sr5. Sadly sold vp s
    Oct 2009
    sa
    Default how hard is it to fit a calias climate control into a vp spac
    as the title says can it be done if so how
    and is there the wires there already or not ?
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    best bet get a full body harness out of the calias and swap them over as the have different plugs ect you will need to pull the full dash out i did mine in a vr and it took me a full day but by the end of the day i had a full s1 vr stato dash with level 3 cluster power windows climate control and cruise control ect best thing ever i ever did to my car
    Oct 2009
    sa
    hahah ok then just wonderin if the wires where already there lol
    but cheers mate
    tivoom's Avatar
    VR S2 Wagon
    Jan 2009
    newcastle
    na there not and the heater box it self is differant if your keen on doing it go to a wreckers and ask them for a body harness and if you can pull the harness out your self save you a bucket load and you get to trash a car lol plus you find all sorts of things in wrecks
    Oct 2009
    sa
    tivoom's Avatar
    VR S2 Wagon
    Jan 2009
    newcastle
    thats gold i found $27.30 and a pair of power window switches lol in the last car i took a loom out of at a wreckers so i was pissed when they charged me $35 for the harness
    Oct 2009
    sa
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    u need some of the calais wiring and the hvac box and climate control module.... private message 88greenvn as he has detailed instructions of the mod - its doable in a day.
    Vn
    Nov 2006
    Glen Iris, Vic
    its not so hard to wire it in, its only about 13 wires that you need to patch which are all pretty localised aside from the brown wire that goes over to the ecu for the climate control trigger. but then again its just as easy to do a body loom swap and you'll get the added bonus of power windows if u dont already have them, lvl 3 cluster, cruise if you don't already have it.
  1. climate control conversion a success not so hard as others say
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-08-2010, 04:41 AM
  2. climate control,how does it work need to know for climate control conversion
    Last Post: 09-07-2010, 12:49 PM
  3. [VR-VS] How to change Heater Control globes (NON climate control)
    By Fonzie in forum Holden Commodore How-To's
    Last Post: 03-08-2009, 11:28 PM
  4. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  5. vy acclaim hard to change manual climate to electric climate???
    By tyrone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-08-2008, 07:43 PM
