Results 1 to 8 of 8
Thread: Help! vp strut tower issue
    VP exec
    Feb 2009
    Default Help! vp strut tower issue
    Hey guys and gals,
    I've got a vp commy, just changed over the strut towers...(getting a defect cleared)...having an issue with a bolt not doing up. It is the bolt on the lower control arm (think that's what it's called). That main big bolt that attaches to the underside of the strut itself is just spinning when I try to tighten the nut up, and from what I can see underneath there is no way of holding the bolt still to tighten the nut up...is this bolt meant to spin or has it broken somehow?
    Am i going to have to hit up the wreckers and get a new control arm or is there a way of keeping the bolt still to tighten the nut?
    Cheers Dallascowboy
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    haha lol no it hasent broken this is why you really need to get this stuff done at a qualified mechanic's shop
    the problem is it is a taperd interfirence fit with a locking nut i dont know how you got it out of the taper to start with but it might need a shop powerd rattle gun not that super shit stuff
    vr berlina
    Aug 2010
    australia
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Sounds like your refering to the lower ball joint (yes it is supposed to spin, the strut pivots on this joint) , try jacking the suspension up under the lower control arm to put pressure on the joint as it is a press fit.. or could wait till its back on the ground to torque it up
    Power is measured in DECIBEL
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Me am agreeing, jack up wishbone to put taper back in place and it'll tighten up goodly.
    Warranty Void
    VP exec
    Feb 2009
    cheers guys will get onto it....didnt take it to mechanic cause im a full time uni student so need to save money where ever i can!
    cheers for the help
    Dallascowboy
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    line the taper up as straight as possible and strike it underneath with a hammer. It will force the taper in so it grips and you can turn the nut.
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    vr berlina
    Aug 2010
    australia
    that would damamge the ball joint seat at the botom of the ball joint
    i agree jack it into the joint but i just push them in with my hand and rattle them works for me
  1. Cracked strut tower
    By PURPLE VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2009, 04:18 PM
  2. VT Series 1 Strut Tower.
    By Old Timer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-03-2008, 10:00 PM
  3. Strut Tower Brace
    By Leno in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-05-2007, 11:06 AM
  4. Strut tower damage - how to fix?
    By synoptica in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-11-2005, 10:51 AM
  5. Strut tower brace
    By blue alliance in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2004, 09:08 AM
