VP aircon controls
P
Pico
Guest
The contols in my vp for my A/c are not working. i cant change where the air comes from.. ie blow on the feet or out the top vents. also the heat and cool switch dosent work. both switches move but nothing happens... Vacum Problem maybe???? I dont know. :confused:
nathans1987
W.A. Perth
4316.awardspace.com
VX SS 5.7L M6
the heat cool switch is not a vacume its a rod leaver action thing that connects to the heater unit at the drivers feet mine comes off all the time i just put it back on
FXST01
The Grey Man
Perth, WA
VP V6 Exec
For the vacuum, check under the left front guard for a black plastic ball shaped tank. Remove the hose to see if there is any suction.
Also if you have ever removed your air filter box you may have blocked the hose that runs to the tank.
R
rattattack1313
Guest
have a looook inside the tunnel by your left foot..ther eis a little white bit that goes on the control rod...falls off sometimes.....
