Results 1 to 11 of 11
Thread: T5/cluch problem???
    VN SS 5.8Lt / VN Exec S2
    Sep 2005
    Central Coast, NSW
    Default T5/cluch problem???
    ok, yesterday i heard a considerably load 'snap!' come from the gearbox/clutch area... scared the hell out of me! lol. now ive got the sound of something spinning, closely followed by a grinding noise. all these noises happen while the foot is off the clutch pedel and once my foot is back on it, even just lightly, it stops..... can anybody help me out?? there arnt any other obvious problems. T5 shifts fine and the clutch doesnt seem to slipping... wat the hell is going on?
    VN T5
    Jun 2010
    Geelong Victoria
    got me stumped, if i was you i would pull out the box and check everything out, maybe thrust bearing, when i pulled my thrust bearing out the plastic grooves were completely snapped off lol goodluck
    VK V6
    Mar 2010
    NZ
    vx gen111 wagon
    Jul 2009
    perth
    Nah the first thing I would check as this happened to me is the return spring on the pedal under the dash there is a how to on here some where 5 dollar part before you start pulling gearboxs out
    VK V6
    Mar 2010
    NZ
    How would that cause a grinding noise? If the thrust bearing is badly damaged it could be working away on the clutch fork by now, best not to cause any more damage by putting it off
    edit: just get under the car and see if there is excessive play in the fork, that will tell you
    vx gen111 wagon
    Jul 2009
    perth
    mine was the same a rattle and grinding sitting at idle but if I just touched the clutch or put my foot under the pedal and lifted it up the noise went away replaced the spring and all good again
    mischa's Avatar
    mischa is online now <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by david dubbo View Post
    Plus one for this, just check it stan. But most the time you will see part of the spring laying in the footwell. If it is this theres no problem driving it around, I replaced mine in the V6 only to have to break about a year later again so ive just left it...
    If you need somewhere to take your gearbox out come for a roadtrip
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    Sep 2005
    Central Coast, NSW
    ok just checked the footwell and no broken spring lol, but, i did have a feel up the back of the pedel and i could feel a spring thats obviosly broken so that probably was the loud snapping sound i heard... but i still cant see how that spring can cause all those noises though. now, the spinning and grinding noise has actually stopped so im not freaking out as much but i think i mite take a peek underneth on the weekend. Cheers for everyones help and Mischa, i'll hold u to that
    202injected's Avatar
    202injected is offline Quality Engine Builder
    VZ Exec. 3.6
    Oct 2005
    i had a simialr noise and here are the results
    mind you circle work in third gear was the main cause
    but normally it means either the cable has snapped ot the thrust race has shit itself
    Attached Thumbnails Attached Thumbnails T5/cluch problem???-31072010084.jpg
    HUNTERMOTASPORT
    Mild To Wild, Your Engine to Your Budget
    no more VK cancer got the better of her R.I.P.
    kitted 3.8lt 5 speed T5 manual VN S2 Commodore
    Jul 2010
    N.S.W , Coffs Harbour
    i had a noise in mine and it was the flywheel was moving and holy shit that was scary
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    If the take up point and feeling of the clutch hasnt changed the thrust bearing collapse or wearing out probably isnt a cause.
    My guess is the clutch return spring(actually preload spring) which pushes the throwout bearing against the pressure plate fingers when you have your foot off the clutch maintaining constant pressure...so when it breaks the throwout bearing then just skims the fingers touching them now and again ...creating a noise sometimes the noise dissappears but that is just a random thing where the throw bearing has stopped after you take your foot off the clutch. Give away is that you can pull the clutch pedal up towards you and it will just sit there and not spring back to the contact point when you let it go.
    It was impossible to get the spring on how they say to so I put it on a different way so it still worked but wasnt nearly as tight.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. idle problem, very difficult to find problem
    By calais s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2010, 10:51 PM
  3. Central locking Sv6 problem. this going to be a problem car??
    By philsv6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 21-04-2010, 10:40 AM
  4. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  5. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
