I push the air con button and the compressor dosent kick in. what should I be checking? I have checked the fuse under the dash and the one in the engine bay and both are fine.
out of gas the system has a low pressure cut off switch to save the compressor getting damaged when the gas is to low
VN Calais With All The Factory Fruit I Need!
Yep agreed. You should be checking the yellow pages for someone to regas / test for leaks.
QldKev
how much is a regas?
It's worth doing the regas before the system gets too much moisture in it and roots your compressor. The gas does get slowly used up over years as the gas/oil mix makes its way past the seals in the compressor. You could have a faulty pressure switch on the reciever/dryer (shiny silver coke can with pipes on it and wires for pressure switch) but it's unlikely. Budget $120 or so and get it done by an auto electrician with the right equipment (Ring around and make sure there's a warranty). System has to be vacuum evacuated first and the right amount of gas added and the oil level checked.
Make it a priority, if the compressor winds up damaged you're up for a grand.
Warranty Void
