Hey guys my trany doesn't go into gear propley until it walms up
basicly trannyslams it's self into gear is my Trany stuffed ??
could be, but might not. have you checked the fluid level at all? if its a bit too much over or under it can cause lots of problems for your tranny. also how long since your last transmission service? if its been a while i would suggest you get a fluid and filter change done on it and add some additive called 'lucas transmission fix'. its bludy good stuff trust me, fixed my transmission problems up within a week. it retails for about $20 at repco and super cheap auto. thats just my suggestion you try before you write off your transmission and spend hundreds on another one. anyway mate, good luck with it![]()
If his details are correct, it is a manual.
If this is true, it's ####ed. Get it to a mechanic.
