Hey guys...
I have a series one radiator in my car and am in need of a new one. I personally want to get a big thick mofo but they are only made with the radiator cap on them.
How hard is it to convert to be able to use this radiator?
What do i need? what has to be done?
Thanks a heap!!
I build websites for cheap.
Aussie desert coolers make whatever you want mate, I've bought several over the years, phone them.
Warranty Void
just send the hose over to your filler bottle and make that the new over flow
Thanks for the feedback guys!
You will need an extra tube fitted into the top of the tank near the radiator cap to connect the bleed tube from the inlet manifold. You can then use the original plastic tank for the overflow bottle but would probably need to drill a very small hole in the cap so it is not pressure sealed, I am guessing about the cap. I fitted a VN V8 aluminium radiator to my VC running a S1 V6 and used the original overflow bottle from the VC. I mounted the fitting for the bleed hose as close as possible to the radiator cap and it works fine.
i got a pwr with my 355 stay cold its good as![]()
Ive contacted PWR.
Thanks. Any idea how much they cost?
Over 900 bucks... not really looking to pay that much, its only a vn lol
If you speak to Norm Hardinge at Aussie desert coolers and you can pick it up and pay cash it should cost $500 - $600.
Every time I've picked one up he's like: "What did I quote you?" Um...500 or "Didn't you pay already?" Uh....That was last year....
They make good radiators but.
Warranty Void
Im just going to buy a series 2 radiator... but i cant make full sense of NPreston's way of hooking it up, can someone explain a little more clearly what has to be done please?
