Results 1 to 5 of 5
Thread: VP V8 Gas/LPG Pump Wont Shut Off
    VN Calais V6 S1, VP Executive V8 Wagon
    Jun 2009
    Default VP V8 Gas/LPG Pump Wont Shut Off
    Hi All,
    I got a bit of a situation with my VP V8 Wagon Duel Fuel With Donut Tank.
    Owned the car for 6 months now, i have never used the gas system in it.
    Cut a long story short, i heard a relay switching under the bonnet popped the bonnet had a look and its a relay for the gas/LPG system. Everytime the relay would tick the Gas pump would turn on or off.
    The only way i could figure out how to stop it was to pull the fuel pump fuse out.
    The cars ignition is in the off position. The Petrol/Gas switch in the car is on the petrol position.
    I had a look behind the switch a could not find any stray or loose wires. i believe it is something to do with the electrical section of the gas system.
    I don't plan on using the gas in a hurry and need to know if there is any quick fix apart from having to pull the fuel pump fuse out, this would only be a good quick fix if i could drive the car on petrol.
    Any Suggestions, Comments, Diagrams Or Anything Related Feel Free To Help Out Would Be Muchly Appreciated
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    do you mean the petrol pump ?
    if so bridge the relay wiring from pin 30 and 87 to remove this relay control of the fuel pump .
    Jun 2009
    Hi strgas
    Thanks for the reply.
    The relay ticks once after putting the fuel pump fuse back in, give it 30 more seconds then it clicks again and continues that.
    There is a strong smell of gas after doing this for a min or so. If i get in it and turn the ignition over to on i can hear the fuel pump kick in,
    the fuel pump seems to have a continuous hisssssss as with the gas pump it seems to have a pause in the hiss hiss hiss hiss. if you get what i mean.
    The relay is a stand alone one under the bonnet up near the passenger side strut tower. Is there a wire that goes to the fuel pump off
    the gas system to disengage the fuel pump when switched to gas.
    I thought of just disconnecting the whole thing but there is an electronic valve lock fitted to the gas tank somewhere and the fuel pump might be tapped into it somewhere.
    I'm pretty sure its not the fuel pump because i can pull the fuel pump relay out and put the fuel pump fuse in and the pump starts up.
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    It's not a commodore but when the gas is no longer needed on the pintara (switched to petrol), it does shut the lpg off completely until I switch it back.
    Also if the car is cranked but not started on LPG, the Gas shuts off.
    Maybe your LPG switch is faulty? Or some of the wiring is shorting together at the back of it? Could even be a dud relay.
    Just an idea.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    You should be able to shut off the gas supply manually with a tap near the gas tank, then it shouldn't matter.
    Warranty Void
  1. Boot wont shut
    By strikewon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2010, 08:47 PM
  2. VN bonnet wont shut
    By Noy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2009, 07:49 AM
  3. Boot wont shut
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2007, 07:29 PM
  4. A/Conditioning fan wont shut off VS
    By kat62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 04:00 PM
  5. my tappits wont shut up in my vs berlina deos anyone now how to shut them up???
    By lestat21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2006, 09:08 AM
Tags for this Thread
