Results 1 to 6 of 6
Thread: VP - Wont Start, but is cranking over just fine.
    1994 VR Commodore Executive (3800 V6)
    Dec 2008
    Default VP - Wont Start, but is cranking over just fine.
    Hi all, i have looked for the right post to help me but can seem to find a post to help me get a way to check that i am getting fuel delivery to the engine, Any suggestions would be great in regards to checking spark and fuel delivery on a VP COMMODORE...cheers
    VX Berlina S2 Gen 3 V8
    Feb 2010
    Echuca
    First is there enough fuel in the tank? Then check the Fuel pump is working (makes a whirring noise when you turn the key to ON). If that's ok then check the spark. As I recall a mechanic once told me to pull the spark plug lead off and position it near the engine block with insulated pliers, wooden sticks, or just by itself if you can and get someone to crank the engine a little. You should see a spark jump if it's working.
    Word of caution, it kinda hurts if you get shocked though.
    Dec 2008
    thanks for the help. will check this weekend and let you know how i go. CHEERS
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    to check that the coil packs and DFI is fine just pull one of the leads off the coil pack and you will see a massive spark jump from the terminal to the coil pack. my DFI died and it dident do this.
    kitted 3.8lt 5 speed T5 manual VN S2 Commodore
    Jul 2010
    N.S.W , Coffs Harbour
    if ya not getting any spark or injector pulses it could be the crankangle senser
    VP commodore
    Jul 2009
    I had the same problem a few days ago.
    The mechanic came over and gave the fuel tank a kick and it started up, he was able to drive it to the shop and fitted a new fuel pump. All up it cost me $300, after reading on here i could have done it myself for around $100 but i needed my car so didn't really have a choice.
  1. sometimes wont start, can take minutes of cranking, but runs great
    By gsxrdan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-07-2009, 03:46 PM
  2. 304 vq v8 tacho jumping when cranking/no start
    By clubsport_replica in forum V8 Development and Modification
    Last Post: 30-04-2009, 01:19 PM
  3. Car wont start, not even cranking
    By bsbozzy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 08:58 PM
  4. Slow Cranking, hard to start hot.
    By Alspos in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2006, 07:21 PM
  5. VC SLE Wont Stop Cranking
    By pjdigital in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-04-2005, 08:51 PM
