Results 1 to 6 of 6
Thread: Series one manual question.
    VR 3.8 exec, big pajero, 5speed vn v6 play car
    May 2006
    Default Series one manual question.
    I use to know the answer to this but it seems old age is getting to me and making my memory a little hazey.
    A bloke at work has a vn series one manual and he wants to rip the series one engine out and replace it with a series 2. As far as the gear box fitting up to the series 2 engine it will go straight in wont it? Or does he need the series two flex plate and stuff? Cant remember for the life of me
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    Yeap,age can be a real bugger. I do remember a series 1 manual engine will only bolt up to a manual box & series 1 auto wont bolt up to a manual box. from memory there is also 2 types of flexplates,a 5 bolt & a 6 bolt??. with the series 2 they fixed the problem with the cranshaft allowing manuals & autos to interchange. the blocks between series 1 & 2 are the same so the gearbox should bolt up. i am fairly sure because of the different bolt types for the flexplate that he may need the flexplate as well,simply because he may not know he bolt configuration of the flexplate in the vehicle. so realistically it may be easier just to get the flexplate to match the engine in the vehicle,a new clutch pack & also as a preventative measure replace the rear main seal at the same time hope this helps
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    Black VN MANUAL
    Feb 2007
    Top of Vic
    S1 Manual motor has 6bolts same with s1 auto motor, but the manual motor are spread apart further so its hard for conversions, but you want to put a s2 Motor in the VN and keep the manual so you will need a 8bolt flywheel and with the s2motors auto to manual are the same on the crank to bolt up to, and the manual gearbox from s1 vn to s1 vs are the same, so all you need is the s2 flywheel 8bolt and it will be fine. dont know about the above post with 5bolt flex/flywheel
    ~ VN POWER ~ Click the scales
    Black VN MANUAL
    Feb 2007
    Top of Vic
    The S2 motor will bolt up to the s1 manual box, all you need is the S2 8bolt flywheel and the clutches are the same aswell, basically it really.
    VN SII And VQ SII
    Sep 2005
    Melbourne VIC
    You will also need a series 2 spigot bush, as they are different. They are still available from Holden for around 5-10 bucks.
    Please PM me if you know of any L67's complete with loom and ECU are for sale
    vn
    Dec 2009
    hey guyz i have a vn series one auto and i have a vn series 1 manual no i want to put the s1 auto to manual just wonder wat i need i have both complete cars just wondering if there anything i will need thanks
  1. Doing Manual Conversion on VP Series II v6, Wiring Question (need quick replies)
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2009, 09:13 PM
  2. ecu question for manual conversion in vs series 2 clubsport
    By clubby_you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2009, 11:56 PM
  3. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
  4. Will a VN series 1 manual g/box fit onto VP series 2 motor?
    By VPioneer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2007, 05:27 PM
  5. Convertting to a series 1 engine from series 2 AND question about oil pick up
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2006, 07:37 PM
