Results 1 to 3 of 3
Thread: changing vp struts
    VP Wagon
    Mar 2009
    Default changing vp struts
    hey guys searched for a while but couldn't find anything on but i need to change my front struts on my series 2 vp wagon and was just wondering whether it is a reasonably easy job and any common problems that may occur whilst doing this, also is there anything else i should change while replacing the struts.
    i was thinking of putting in an adjustable strut top and new sway bar links but not sure on what else to do.
    cheers
    calis vn v8
    Jan 2008
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    You mean the shocks right? Not replacing the whole strut? Well either was when you take the strut out dont bother with the ball joint take the whole control arm out with it, its a presses job for the ball joint. I recently done it to the V8 http://forums.justcommodores.com.au/...-bt1-v8-3.html
    If it was me replacing the shocks i would also get some new springs if its stock height and strut tops if the old ones are shagged. I also found my shock boots and bump stops where gone aswell.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  1. struts?
    By mynameisearl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-07-2010, 07:23 AM
  2. Changing Bonet Struts
    By Grennan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2009, 07:37 PM
  3. changing front struts/springs
    By somerandom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-04-2009, 11:05 AM
  4. changing front struts on my vs commodore
    By tbblitz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-01-2007, 04:19 PM
  5. VR/VS Struts into a VN
    By mechanic22 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:29 PM
Tags for this Thread
