Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Swapping Instrument Cluster
    '92 VP Commodore Exec Manual
    Jun 2010
    Auckland
    Default Swapping Instrument Cluster
    I have a 93 VP commodore with level 2 instrument cluster. Someone's wound back the odometer and broken it so I was hoping to replace it with another level 2 cluster but roughly the correct distance on it.
    My cluster currently has green around the dials (I'm sure you guys know what I mean) and I've sourced a cluster from a 94 VR. It doesn't have any green in it - just plain white and black.
    Is the only difference the face plate?
    Is there anything special I should know or can I do a straight swap?
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    i dont think you can put a vr/vs cluster into a vn/vp,something to do with the thing on the back is wired different and can cause a fire going on from what ive read over time.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    As above DONT put the cluster in. VR/S clusters cant be swapped with VN/P. Just find a cheap VN/P one.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Jun 2010
    Auckland
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by Paulib View Post
    so vp's can only handle vn or vp level 2 clusters?
    You can use any VN/P cluster, including a level 3 one from either model. You need to wire in the trip computer for the level 3 tho (or you could leave it, but then you wouldn't have an odometer)
    cheers sexy
    kitted vp's Avatar
    kitted vp is offline project vp
    kitted vp exec wagon
    Jul 2010
    gold coast
    ive got a level 2 vp cluster in perfect working order with 168000 on it that just came out of my vp just yesterday when i did the level 3 upgrade private message me if your interested and we can sort something out also i just seen you live on the other side of the ditch we can use paypal if your worried about being dodgyed
    Jun 2010
    Auckland
    kitted vp's Avatar
    Jul 2010
    gold coast
    calais and statos definately did probably some other models too example ss and so on not berlinas or execs
    STEALTHY™'s Avatar
    Jan 2005
    Standard on VN/P Calais and VQ Stato, optional on everything else.
    cheers sexy
    kitted vp's Avatar
    Jul 2010
    gold coast
    oh ok so they were an optional extra i would have thought by all this talk of different looms on the level 3 conversion thread that it wouldnt have been an option on some models? well there you go you learn something new everyday
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by kitted vp View Post
    They would just use the loom with the level 3 plugs if the option was ticked when you bought it new.....
    cheers sexy
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You can fit VR/VS gauges to your VP cluster (which includes the speedo). This is a 5 min job if you have the Level 2 VP cluster. All the holes are the same. BUT only swap the gauges and speedo - you cant use the PCB on the back of the cluster or the voltage regulator.
    I've now made over 20 of the VN/VP to VR/VS gauge swap clusters without a failure yet. I'd say there are several VN/VP drivers very happy with them as the tacho's in the VR/VS are 100% better than the VN/VP units.
    and 3 Dangerous non ABS VN's
    Jun 2010
    Auckland
    Does that swap the odometer over too? (which is my main reason)
    Is there a how to on swapping just the speedo and tacho? (athough I assume its a straight swap)
    88GreenVN's Avatar
    Jun 2006
    It's a straight swap. undo 7 nuts for the tacho and temp/fuel gauge and remove. Unclip the speedo head ribbon and 4 screws. Put the VR gauge set in and your done.
    No modification is needed if your swapping from level 2 to level 2.
  15. #15
    Jun 2010
    Auckland
    sorry for all the dumb questions - but will the vp then have the vr odometer? Are the speedo, tach, odometer, fuel and temp gauge all one object?
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Ask as many questions as you like - so you feel that you can do the job. The 3 parts to the cluster are the same and in the tacho, speedo & temp/fuel gauges. they are joined by 2 black strips - you will see when you take the lens off.
    So lens off - 4 screws, slip the 2 joiners out the top - and then remove the gauges as said above.
  17. #17
    VL berlina - Daily / VS Berlina - Project car :)
    Aug 2010
    Craimore, SA
    Well my mate has a VP-S-pack, and he wants to upgrade from level 1 to level 3
    Can it be done???
  18. #18
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by SikVScommi View Post
    Can it be done???
    Yes. All 4 gauges will work just by putting it in. If you want the trips to function, you will need to splice into your loom (and buy the '4th plug') and wire it up. Theres a how to guide on here somewhere.
    cheers sexy
  19. #19
    Aug 2010
    Craimore, SA
    Mad as
    Yea cos i got the V3 Cluster and trip comp, just gotta put it in lol
  20. #20
    88GreenVN's Avatar
    Jun 2006
    Mad as
    You will also need to mod the switchblock to work the 3 modes in the trip computer - if you wire it up hit a 4th plug. The L3 switch block will not work as the wiper part is controlled via the BCM and will smoke if plug into the normal loom.
    You can get a VN switchblock and use the guts out of that to put into the VP switch block. The VP PCB out of the wiper switch is then mounted remotely under the dash and wired into the loom so the rear demister and interior light delay still function. I've done 11 VP upgrades now and it takes a little extra work - but the L3 is a specky upgrade over a Level 1 dash.
  21. #21
    Aug 2010
    Craimore, SA
    So ur saying if i put the L3 Dash in, and put the wipers on, it will smoke???
    WTF
  22. #22
    88GreenVN's Avatar
    Jun 2006
    WTF
    No - if you fit a level 3 wipr switch to control the trip compouter when wired in - it will smoke. Level 3 wiper switch is very different to the L1 unit.
  23. #23
    Aug 2010
    Craimore, SA
    Ohh, do u mean all the buttons round the cluster, like calias ones wif cruze and stuff???
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Yes - if you want to change the mode the trip computer is in (has 3) dont just fit a Calais switch block cos it will just frazzle - trust me it's been done a few times
  25. #25
    vx gen111 wagon
    Jul 2009
    perth
    listen to what 88greenvn says he walked me through my conversion and everything works perfect
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. instrument cluster - help!
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 10:01 PM
  4. Instrument cluster
    By Fu Manchu in forum Electrical Wiring / Questions
    Last Post: 06-04-2006, 08:53 PM
  5. Instrument cluster
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-04-2006, 04:37 PM
