so - had the car a long time, and decided to try and get the cc working.
this was not hooked onto the throttle body when i brought the car.
looked at some threads - all lights come on, green on cc control, orange on dash,
hooked the cable to throttle body and it seems ? maybe ? the housing for the spring is smashed off - as this always wants to fall off and pull the throttle open......
has any one have a good pic of a vn v8 1990 set up on the cruise control.
well well, after looking at photos on net i have found that i am missing part of the bracket also,
looks like the bracket at the throttle body end is v shaped - mine is straight in the air and my cover off the spring is missing...
so i have flattened a bit of round 10mm aluminium and bolter under a bolt and made my own![]()
now working on spring cover......then test trial - probably jam open and wipe out into a cop or something way my day is going![]()
Go the the wreckers and buy the missing bits - cheap as these days.
and 3 Dangerous non ABS VN's
Buy a donor car from the auctions.
Warranty Void
well - I found out what cruise control good for ?, and yes - it works with my make shift bracket !
Its good for sitting back with your missus giving you a blow-job, 6 or 7 years had the car and only thought to sought it out today....!!
Did not need to know that at all. Thanks
