Results 1 to 6 of 6
Thread: Is this a good idea?
    Whiteford88 is offline 38PONT
    Holden Commodore VN V6
    Jan 2010
    Tamworth, NSW
    Default Is this a good idea?
    Hey guys, today I was pissing around with my engine a little bit, cleaning the engine bay and what not and now I have on my 3.8L V6 my pod is hooked up directly too the tb (besides the rubber arm) and it sits just above the exhaust manifold. Now I am wondering if because it is above the manifold that it will constantly suck in hot air and decrease performance?
    Thanks in advance fellow commodores!
    ducker85's Avatar
    ducker85 is offline Calais man
    09 VE clubbie R8
    Oct 2008
    Adelaide SA
    Quote Originally Posted by Whiteford88 View Post
    bad idea unless your motor loves hot air but generally people try to get cold air in
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Cut hole in bonnet.
    Build box around underside of pod.
    Profit!
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Yep - bad idea - if your out to get performance. Else it dont really matter.
    and 3 Dangerous non ABS VN's
    Jan 2010
    Tamworth, NSW
    Yeah I changed it back because of the air heat issue. Thanks anyway guys!
    04 VY SS
    Aug 2010
    Perth W.A.
    I've usually seen dudes going the "two hole mod' and a K&N panel filter rather than chucking a pod straight onto the intake pipe - if you are running a pod filter you will require a housing of sorts that will separate the pod from the hot air around the engine bay (if you are good with fiberglass it's a good start - some places do sell an ready to go aftermarket "housing" for you to mount into the spot your stock box is usually located and you just mount your pod into that... although the ones I've looked at are usually intended for V8's... Personally I have the over the radiator "bigmouth" SS Inductions CAI which works a treat.
    Remember:
    Cold Air = Good
    Hot Air = Bad
  1. Good Idea? Bad Idea?
    By WogBoyz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2009, 01:00 PM
  2. Good idea
    By lgnd3800 in forum Jokes/Humour
    Last Post: 04-02-2008, 03:25 PM
  3. Not a good idea
    By Pretender in forum The Pub
    Last Post: 03-05-2006, 03:56 AM
  4. Good Or Bad Idea?
    By bad_boyz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-03-2004, 11:19 PM
