Which engine do you prefer? S1 or S2 V6?
Give reasons, I honestly don't know the difference between the two accept the S1 is a buick which is what I have. Discuss (:
S1 is better from a standing start but anyone who has had to replace a thermostat in an S1 engine would probably forgo the little bit of extra oomph off the line for the ease of changing a front mounted thermostat on an S2 engine
If ignorance is bliss why aren't there more happy people around ?
the engine in my VR is an S2 bottom end with (modified) S1 VN heads. There are a couple of minor differences between the two different engines, S1 has different coolant passages and there is a bit more meat around the ports to grind away. PCV system is different also. The injectors on the S2 fire in two sets of 3, instead of all at once like on the S1 (not that it matters, given the speed they operate at).
There isnt really much that makes one engine hugely better than the other, though.
I like the aluminium rocker covers on the early S1.
agree with crazyspoon, if you need to change the thermostat, Series II is the go. 2 mins vs 2 hours
My VN Calais had a S1 engine, it had a awesome take off. But it was slightly harder to find parts to suit a S1 engine.
I now own a VP with a S2 which has a poor take off but great mid range.
If i could change my engine it would be a S1.
Great responses.
My VN S1 has 216xxxKMs on it and the take off is still unbelievable, and even 6,000RPM is insane (:
And what about to modify? If you had the opportunity to put ultra light rockers, throttle bodies, ect ect which engine would you rather do it too? Which engine do you think you would get most out of with modding?
there is a new set of high ratio rockers just released for the s1 v6, can't remember who but, might be mace??
s1 are the go i reckon ive had both and prefer the s1 after doing 1 thermostat its easy as and u can do it in an hour lol
10 liters of aussie v8 cant go wrong
@ Above
Yeah, I've taken a look at the placing of it and what not, it looks like a bitch to get at lol.
can i put the s2 inlet manifold on a s1
yes you can.
But a Vt doesn't have a buick motor.
nar ian builden a turbo vn
Ok then.
Standard manifold might not be the best idea.
Nah manifold will still fit, the t/stat will be at the wrong end (but still work) and you will probably want to block off the PCV pipe at the manifold end. It is blocked off anyway, but blocking up the other end will stop it filling with grease and crap.
Yella terra make roller rockers for the S1 and S2 buicks - Make sure you get the right set though as the stud size is different and they dont interchange.
Im going to say VR engineapparently had supercharged rods from the U.S and higher compression (9.0:1 instead of 8.5:1).....
And with series 2's it's easier to change a thermostat and plugs on the drivers side.
well can i put the heads off the series 1 straight on the series 2 coz thay have been ported and polished sorry about all the questions iam still learning
rito can do thank u
