Results 1 to 7 of 7
Thread: Problems with new Boss Kit... Help??
    1996 3.8L VS Commodore
    Aug 2010
    Watanobbi
    Default Problems with new Boss Kit... Help??
    i just got a secondhand boss kit for my vn and i was just putting it on and it got really tight about half a cm from the copper rod and heard a metal fracturing noise so i took the nut back off and checked for thread damage but nothing, should i just keep tightening or what...? any suggestions
    HX Kingswood Ute (Project)
    VN Berlina (Now a Donor)
    "91 Subaru Liberty (Blown Motor Ex-Daily)
    VS Commodore (Daily)
    vx gen111 wagon
    Jul 2009
    perth
    proobably not find what fractured be sure to check the whole steering colum
    Aug 2010
    Watanobbi
    well ive looked around and their is nothing obvious, also their is no reason for anything to fracture, its tight but it keeps going down the thread... one thing i did notice but underneath the washer that sits between the boss and the nut there was like a ground out line, and metal shavings inside it...
    ? could it have been that that i heard, and should i leave that spring behind it in or take it out?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Your not meant to do it up very tight maybe just couple of turns after finger tight if that, you may have damaged the steeing column these cars have a colapsable steering column for when you hit it in a collision. And are you sure its the right boss for the car and were all the little bits included?
    WH STATESMAN
    Oct 2007
    Ballarat
    I'd have to wonder if it is the right kit, a boss kit should go on easily without force.
    VX Berlina - GENIII
    Mar 2010
    Qld, Australia
    Aug 2010
    Watanobbi
    cheers people. i ended up askin my brother to hold the wheel while i tightened... it went on. what little bits, i pulled it off a vn at the wreckers myself and all there was was a gnd wire for the horn now yous are worryin me... collapsable steering column...? please elaborate, how will i know if i have damaged and will it collapse or do anything while im driving if i have damaged it? the wheel is on and it turns left and right full lock no funny noises or anything...
  1. Boss kit problems
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 10:37 PM
  2. Boss kit
    By dbarnes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2009, 06:51 PM
  3. the boss
    By dsnutz in forum Jokes/Humour
    Last Post: 04-07-2006, 09:21 PM
  4. Is CA Boss the same as effects Boss?
    By semi in forum Car Audio
    Last Post: 08-01-2006, 02:30 AM
  5. VS Boss Kit
    By raZel in forum Swap / Wanted to Buy / Trade
    Last Post: 04-07-2005, 12:28 AM
