Results 1 to 4 of 4
Thread: alternator problems
    vn commy
    Jul 2010
    nz
    Question alternator problems
    hello my alternator shit itself so i sourced a new one suppoed to be reconditioned however turned out to be a dud so got two more and so far neither the one i pulled out of it or the other three i purchased work is this an alternator problem or a electrical system.
    note the alternators purchased were said to be reconditioned by a specialality company.
    VY SS
    Jun 2006
    Albany
    sounds like something is wrong in your car, make sure you are getting power to the alternators positive terminal. you also need to make sure the 2 pin plug on the alternator is also getting power when you turn the ignition on.
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I had a problem on my old VN where the battery wasn't charging. Tried a new battery and a couple of alternators before finding out a fusible link had burnt out. Few dollars later and problem solved.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    also check the earth strap from battery to inner guard.....mine was busted and mimicked a dead or dieing alternator
    VN Calais With All The Factory Fruit I Need!
  1. Alternator problems??
    By 6 shooter in forum V6 Development And Modification
    Last Post: 28-04-2010, 08:27 PM
  2. v6 alternator problems
    By ibt18u in forum Electrical Wiring / Questions
    Last Post: 30-08-2009, 03:35 PM
  3. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  4. Alternator Problems. HELP!
    By 33som in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-12-2008, 12:48 AM
  5. Charging problems? wtf? (alternator?)
    By padrickz88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-12-2008, 09:08 PM
