Results 1 to 7 of 7
Thread: steering wheel question
    vn calais
    Mar 2007
    epping
    Default steering wheel question
    Does a vs (non-airbag) steering wheel fit on a vn?
    vx gen111 wagon
    Jul 2009
    perth
    Vn Berlina
    Jun 2009
    sa
    i think vr & vs needs some sort of adapter, my vn has a vr wheel on it but i hav'nt taken it off yet. but i was in a commodore wreckers a while ago and they had on the shelf "vr steering wheel with adapter to suit vn" which caught my eye.
    TrikkBen's Avatar
    TrikkBen is offline Compulsive.
    BNR32
    Apr 2009
    SE, Vic
    pretty sure the VN through to VS had the same "hub"
    There is no such thing as stupid questions, Only stupid people.
    Dec 2009
    I put a non airbag VR wheel off an S pac ute onto my VN sedan and it fitted straight on. They use a different puller though, the VN one you use bolts the VR one you need hooks to lock into the back of the holes in the wheel if you want to get it back off again.
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Don't get the LASER brand 'GM' puller on Ebay though as one of the arms doesn't go through one of the holes on the Holden wheels, wondered if my wheel was dodgily made but tried the puller on a few other VR/VS wheels with the same result
    Ended up having to spend ages manually to remove the wheel
    If ignorance is bliss why aren't there more happy people around ?
    Dec 2009
    Quote Originally Posted by crazyspoon05 View Post
    I've got home made pullers for the VN and VR steering wheels, the VN one is basically a bit of 20x3 steel bar with 2 holes drilled in it that match the holes in the steering wheel and a big bolt taped onto the centre. Simply undo the nut on the steering shaft until it is proud of the shart, place the bar over it with the nut towartds the shaft and put 2 bolts through the rod into the steerign wheel, do the bolts up evenly and the wheel pops off.
    For the VR same deal except you use threaded rod or 2 bolts ground down to make 2 hook like ends that lock into the steering wheel.
  1. Steering Wheel Question
    By Cool D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2009, 08:05 PM
  2. VS Statesman steering wheel question (regarding the airbag etc)
    By mike49 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2009, 01:30 PM
  3. steering wheel question
    By reaper01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 12:51 AM
  4. shake in steering wheel question please
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2008, 11:03 AM
  5. Sports Steering Wheel Question?
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-08-2005, 05:15 PM
