Results 1 to 8 of 8
Thread: VR power steering rack into VP
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    Default VR power steering rack into VP
    hey guys just wondering if a steering rack out of a VR 1994 will fit a VP 1992?
    also does it matter if its v6,v8 auto or manual?
    cheers guys
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I believe it should fit fine. Will need a wheel alignment though, cause of the different track
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    Dec 2009
    Just check to make sure the actual rack gear and rack ends (tie rods) are the same length in a VR rack to a VP rack.
    VR's I think have a wider front track.
    Vn Berlina
    Jun 2009
    sa
    Quote Originally Posted by wortus View Post
    you are right, i have found that the front track is wider, you can change the rack ends over to make it fit but the gearing inside the rack is set up to suit the wider front track.
    i found this out by attempting to fit a vn rack into a vr. the rack ends were too short so i had to swap them over and then on the road test the turning circle was shit and i was hitting lock in the rack before i would hit the lock stops on the steering knukles
    Dec 2009
    I am pretty sure that the length of a steering rack gear is the problem your having there. It's length should pretty much be the same as the distance between the lower arm inner pivots. I remember reading this somewhere on a web site that supplied modified steerign racks for Torana's and rack and pinion conversions for older Holdens with a steering box.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Wont work, the racks are different length. Ive tried it.
    I have a pic of the two side by side for comparison, il try and find it
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VY II "S" ute :)
    Dec 2009
    NSW West Sydney
    lucky i didnt buy it yet :P
    that photo would be cool mate if ya can find it.
    cheers
  1. VR power steering Rack into VN?
    By HT_Monaro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2010, 07:33 PM
  2. oil line from power steering to steering rack
    By onmy6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2007, 10:08 AM
  3. VR POWER STEERing Rack HElp!
    By damotheking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 11:03 AM
  4. Power steering rack
    By dale- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-09-2004, 05:10 PM
