Results 1 to 20 of 20
Thread: How wide tyres can I go with stock rims?
    92 VP Series 2
    Jan 2009
    East Brisbane
    Default How wide tyres can I go with stock rims?
    Hey so I have some stock rims with the standard 205/65r15 tyres, but they are overdue to be replaced and im just wondering how wide tyre I can go. The rims say 15x6, so would I be able to get a 225 wide tyre on or even a 215 wide? Cheers
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    You are going to get a lot of replies telling you to go to 245 or 265, but if you do it will be a pig to drive.
    Stick with the 205s mate, they are plenty wide enough for 15x6.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Even with my interceptors I stick with 205. Anything wider is a waste of time not to mention more expensive. 225 is only 2 cm's bigger and the only difference will be a bulging sidewall that will be detrimental to cornering
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Tyre shop tells me they will only fit 225 (max) on a 6 inch wide rim as the sidewall will bulge too much
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    The price difference between 205 and 225 is astounding. Almost double where I live. Personally I would rather a skinnier tyre that had less sidewall bulge the one that had bigger.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    You can run 225's on 6" ceptors.... I run them and they are fine, also the sidewall bulge is pretty sexy :P
    Quote Originally Posted by wraith View Post
    Really? it's like $10 max here lol
    VP SS
    Jan 2008
    Hiding in WA somewhere
    yeah i used to run 215s on my old ceptors to me they were there best
    If its got Wheels or Boobs its gonna cost ya money
    QuickVRII95 is offline Banned
    Patent Pending 1995 VR Series II V6 Buick
    Sep 2010
    Quote Originally Posted by RUF 231 View Post
    They ARE Correct On That... 225's Max On 15x6's... Any Bigger & You Risk Rolling The Tyres Off The Rim... Too Much Flex In Tyre Wall Too... I've Tested This On My Prototype VRII..
    Your A Complete Moron, If You Go Any Bigger Than 225 On 15x6's...
    I Only Run 225's On My Cop Interceptor 15x7's (All Four (Police Standard)).. Plenty Of Traction...
    Sep 2010
    Quote Originally Posted by Andrew426 View Post
    If You Understood What I'm Saying... Yes, A Commodore, Has 4 Cycles & I Didn't Say It Didn't Either... But Essentially IS A 24 Stroke Engine (6x 4 Piston Stroke Cycles Per Cylinder, To Keep Engine Revolving (MINIMUM 24 Strokes To Run)) Get YOUR Facts Right, Before You Slander Someone On Every Post You Type...
    A Lawnmower IS Branded 4 Stroke For A Reason... IT ONLY HAS A MAXIMUM Of 4 Pistons Strokes Per Piston Stroke Cycle, For The Motor To Keep Revolving... You Are Thick As... It's Like Talking To A Brick Wall...
    92 VP Series 2
    Jan 2009
    East Brisbane
    lol QuickVRII95 i think that last post was meant for a different thread hahaha. thanks heaps everyone for your input. so im gonna check out prices for 205/65 tyres and also 215/60 and if they are pretty much the same then ill go for the 215's but if they are fairly more expensive then ill just stay with the 205's. thanks again everyone
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    You really think your going to notice a tyre 10 mm bigger? Hmm.
    92 VP Series 2
    Jan 2009
    East Brisbane
    Part of the point of me asking was in case I came across a good cheap tyre that for example I could get in 215 wide but not 205, or visa versa
    Vn Berlina
    Jun 2009
    sa
    i saw an article in wheels or something, it may have even been the aussie topgear, anyway they were testing the w427 with the massive wheels which i think were 20" and optioned down to 19" with the bigger tyre and it was heaps quicker on the track compared to the first run, oh and they also had to put smaller brakes on it due to clearance issues.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Just go with what ever is cheaper then. If you can get a 215 for cheaper then a 205 then do it. Your going to notice no difference besides the extra cash in your wallet.
  15. #15
    Dec 2009
    I had 15x6 rims on my old VN and I ran 215x60x15's, the bulge was not too bad. I used Yokohama C Drive's which are a very good tyre.
  16. #16
    VZ Exec
    Feb 2007
    Sunshine Coast
    Google kouki.co.uk, it has a guide for min and max tyre widths on rims. and a visual tyre guide ie if you go from 205.65.15 to 245.40.18 it tells you how much your speedo will be out, plus or minus (rolling radius). i found that 205.15 are dearer than 215.15. 215.16 are dearer than 225.16. and 225.17 are dearer than 235.17. 205.15 is an usaual size therefore dearer. just look in a bob jane cataloge and compare prices.
  17. #17
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    mate i run 225/60 r15 madisons on my stock vn calais wheels no drama's and at around 135 a tyre i get good k's out of them and good traction......on my third set in 6 years
    VN Calais With All The Factory Fruit I Need!
  18. #18
    Jan 2008
    Quote Originally Posted by LordMayhem View Post
    VN calais wheels (i think) are 15x7
  19. #19
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
  20. #20
    LordMayhem's Avatar
    VN Calais
    Jan 2009
    Hervey Bay QLD
    haha if they where 7's i'd have 235's on them
  1. Will 185 Wide Tyres Fit On 6 Inch Wide?
    By sweefu in forum General
    Last Post: 12-01-2010, 10:09 PM
  2. [WA] WTB: (4) stock rims + tyres
    By MattyC in forum Swap / Wanted to Buy / Trade
    Last Post: 09-12-2009, 01:36 AM
  3. [NZ] Stock rims and tyres (215/60 R15)
    By JUZDVS in forum Parts And Other Items For Sale
    Last Post: 04-08-2009, 04:05 AM
  4. what tyres can fit stock rims?
    By ari666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-07-2009, 11:10 AM
  5. [VIC] WTB stock vk hubcaps and wide rims
    By ari666 in forum Swap / Wanted to Buy / Trade
    Last Post: 01-07-2009, 10:39 AM
