Results 1 to 6 of 6
Thread: engine squeaking so much!!???
    VN EXEC
    Feb 2010
    Default engine squeaking so much!!???
    hi guys, im getting a constant squeaking sound when i turn on my VN series 2, it sounds like its coming from that rotating blade part at the front of the engine which is rotating really really fast, or at least one of the rotating parts on the belt (sorry my knowledge is extremely basic!)...
    i think i am due an oil change/ transmisson oil change, is probably a few thousand kms overdue, could this have anything to do with it??
    oh and it seems to be rattling an awful lot more these days too....but mainly the squeaking...
    any ideas appreciated
    thanks
    VP SS, Cammed VN V6 daily
    Jan 2010
    i can probably put money on this, but almost certain it will be your water pump. Try taking off your belt and spinning all your pulleys, I bet your water pump will be loose and the inner bearing is shot, the noise is the pump slowly eating metal, mmm nom nom nom
    92 VP Series 2
    Jan 2009
    East Brisbane
    Try the harmonic balancer too, the pulley right at the bottom of the engine. If there's bits of rubber coming apart inside it then you should look at replacing it asap, just another thought...... good luck mate
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    If the knocking sounds have gradually been getting louder then the harmonic balancer is probably the culprit for that
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    VN EXEC
    Feb 2010
    sorry can i get some details about changing the harmonic balancer as i have very basic knowledge, a dummies step by step would be much appreciated!!
    VN EXEC
    Feb 2010
    hi guys,
    i took of my drive belt but the water pump pulley isnt really obviously loose in any way, the harmonic balancer seems a little loose and the rubber on the outside seems like its getting old....but not coming off yet..
    is it possible to change harmonic balancer DIY job? is it an urgent thing????
  1. squeaking noise in air con.
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2011, 11:06 AM
  2. vy engine in vt . but makes a squeaking noise
    By aje516 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:26 AM
  3. brakes squeaking........
    By MattyVRss in forum V8 Development and Modification
    Last Post: 08-06-2009, 01:21 AM
  4. squeaking noise from the engine
    By race4life in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-11-2006, 12:43 PM
  5. Creaking/squeaking GTR
    By rubygirl in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-08-2005, 12:48 AM
