Results 1 to 5 of 5
Thread: a few Qs on removing parts from a vp
    VP SS / HX KINGSWOOD/ 1928 CHEVROLET
    Oct 2007
    Default a few Qs on removing parts from a vp
    Hi guys im going through the process of stripping a vp calais and need a bit of info on how to remove a few parts.
    First question is how do i remove the chrome door moulds .
    second is in regards to the wheel spats . Is the bracket that holds them on welded to the body of the car or are there screws that i cant see?
    Thanks in advance
    NOT THE BLOODY KINGSWOOD
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    With the spats im pretty sure it is cliped on and to remove them you need to take off the wheel and get in behind it i think. Door molds as in the trolley strip?
    Oct 2007
    thanks skidbro.... the moulds in talking about are the ones that run along the bottom of the windows not the ones that are halfway down the door skin
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    To remove the door mould you need to remove the interior moulds that are at the same height, I got to them after taking the trims off but you may be able to peel them off otherwise, use a flathead screwdriver. On each end of the door you'll find a screw behind where the interior mould were, very small, unscrew each one on each end, then using the flathead screwdriver, pry up the exterior door mould and they should slip up and off. Installation is reversal. Can take a bit of force because these little metal clips holding them down tend to rust.
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    Oct 2007
    thanks for the info. will give it a go when i get the time
  1. [VIC] Cleanout> VN parts, WH Stato parts, springs,rims etc.
    By fatbats in forum Parts And Other Items For Sale
    Last Post: 05-05-2010, 08:30 PM
  2. Replies: 61
    Last Post: 13-10-2008, 09:06 PM
  3. Huge Sale Vn Calais - Vs Parts Stato Parts Etc Etc Heaps Of Stuff
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-03-2008, 04:48 PM
  4. help on removing a/c when removing engine
    By sebstenator in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2008, 02:19 PM
  5. Wrecking VN - Selling all parts! Includes parts from later models others non-standard
    By DavidPartay in forum Parts And Other Items For Sale
    Last Post: 27-07-2006, 11:35 AM
