Hey all, I've developed a squeaky clutch pedal in my VN V6, and at first I thought it wouldn't bother me, and that it'd eventually go.
Now, it's still there, not loud, or anything, and only happens at the very end of the pedal travel (Away from carpet).
I've tried spraying Inox (Similar to WD-40) over all the parts I can see that move under the dash, and it's still not gone.
May I have missed something? Or is it something else?
If I leave it, will it do any damage?
go to rare spares and buy a bush kit for around $10.
the clutch and brake pedals have nylon bush in them that do ware over time
NOT THE BLOODY KINGSWOOD
I'll second that gmh... For now get into It with some silicon spray.. It'll stop the squeak for now... Works on fan belts too![]()
New bushes will fix or turn them around
I've done the new bushes on mine, (in my case) it's not that... Seems to be the point were the cable passes thru the very end of the sleeve, on the pedal end. Both my cars do it, tried everything.. no luckSo i just deal with it haha
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
Don't use WD40 it just attracts dirt and shit. silicone spray works best imo
My car did this and it was the worn pressure plate fingers vibrating the throwout bearing and the noise being transmitted down the cable to the pedal...the giveaway was that the noise totally dissappeared when the engine wasnt running.
Before I took the clutch apart to prove it wasnt the cable I took the cable out and checked it and it was alright so then I changed the clutch itself and noise gone but now the pedal vibrates on light application and the problem is its worn on the shaft that the throwout bearing runs up and down on called a bearing retainer........the wear causes the throwout bearing to shimy just when it gets loaded.Got a new retainer to fix it with...only wish I had changed it when I had the gearbox out when I replaced the clutch.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
It could also be the ball pivot inside the gearbox squeaking. Some high temp grease will fix it but you need to remove the gearbox.
Most of the time it's the friction between the cable shackle and the pedal hook. Spray some lithium grease on the shackle every service and it'll never squeak again![]()
The 1972 HQ Kingswood
really sorry I am bumping this thread, but are you able to provide a link to the clutch bush? I'm on rarespares now and can't find what you're talking about. I'm looking to replace mine to see if it solves the problem, my stereo usually masks up the noise (lol) but when it's not on, it drives me insane.
