Results 1 to 4 of 4
Thread: Dash LED issue
    '92 VP Commodore Exec Manual
    Jun 2010
    Auckland
    Default Dash LED issue
    So I tried putting LED's into my dash. A bit dim, and bright spots on the speedo however the tachometer only seems to light up sometimes.
    Thought it could be the bulb - as there was one dud in the pack. But when I changed the bulb the issue was the same in the tacho. It seems to come on and off sometimes over bumps, other times for seemingly no reason at all - when I was testing them I was parked it wouldn't come on at all.
    Thinking it could be the connector thing I swapped that with another lights and no change.
    So I swapped back to the old bulbs and the tacho light works perfectly now.
    Any Ideas different in the LED that causes it to lose power sometimes?
    I want to keep the LED's in - after all its the little things that make the car, but I wont use them if theyre not always going to work lol
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Obviously you have a wiring problem.
    In regards to the LED's, did you file off the domes on the end of them? The dome focuses light, by filing them off it spreads the beam out further giving you more spread of light.
    Jun 2010
    Auckland
    Yea I thought it was just a loose connection but it doesn't happen with the light bulbs which is what stumped me and thought maybe someone had come across the same random issue...
    can you take off the domes? I know nothing about LEDs. So they don't burn out in the air like a normal bulb would?
    Sep 2005
    No the actual light part is further down. You just need to take the domes off.
  1. VT Dash Lighting Issue
    By nickant in forum Electrical Wiring / Questions
    Last Post: 13-09-2010, 12:32 PM
  2. dash light issue.
    By Maccasmack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2010, 05:47 PM
  3. issue with dash swap over
    By fergie_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2009, 03:40 PM
  4. VS dash light Issue
    By Void in forum V6 Development And Modification
    Last Post: 04-04-2008, 07:58 AM
  5. Dash lighting issue
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2007, 12:03 PM
