Results 1 to 9 of 9
Thread: How to change VN front Rotors
    97 magna
    Sep 2009
    Default How to change VN front Rotors
    Can anyone let me know how i can change my front rotors on my VN. They are not like the VS which is alot easyer.
    Thanks
    97 magna
    Sep 2009
    VK V6
    Mar 2010
    NZ
    You need to remove the dust cap, split pin and castellated nut that holds the hub on, along with the bearings. When installing the new rotors make sure you correctly set the bearing preload, you should also at least repack the bearings if not replace them.
    97 magna
    Sep 2009
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    yeah its really simple, make sure you dont drop the wheel bearing on the dusty floor like i did, could use new ones now :-(
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    you have to make sure you tighten the catsleated nut to the right torque and dont use wire as a split pin go buy some
    Dec 2009
    Quote Originally Posted by vr1uz-fe View Post
    It's not torqued up you do them up until the play is gone then back them off one indent. There may be a slight amount of play but it's better than being overtight as they will overheat. New bearings need to be packed as well. Do you know how to properly pack a bearing so you get th egrease all the way through?
    Dec 2009
    VP Commodore
    Jul 2010
    Marion, SA
    Best to clean the bearings in petrol and then regrease them. Buy some wheel bearing grease and knead the grease into all the gaps. Easy, I just changed mine over yesterday and replaced the steering rack today. When you take the breaks off you will need a clamp of some kind like a Gclamp to press the caliper back in. hope this helped. Also you don't torque the castle nuts. Wortus knows where it's at.
  1. [VT-VX] How to: Change pads and rotors.
    By 253@7k in forum Holden Commodore How-To's
    Last Post: 13-05-2012, 08:30 AM
  2. change pads and rotors in vr
    By ital355stroker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2011, 05:03 PM
  3. Where to get HSV front rotors?
    By lockmac in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-11-2009, 07:43 AM
  4. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
