heater take ages to heat up, way too long for my likeings only when the temps half way and that takes about 20min
what could it be, heater core?
It is most likely to be a faulty or missing thermostat.
MY RIDE
I have this problem in my VS and it's not the thermostat. I've rebuilt the engine and it's still a problem. It's got to be something to do with the heater tap.
yeah i second both post change the thermostat first could be stuck open or missing. It doesn't hurt to change it in fact could be a good thing. then if no change do the heater tap. also just check that the radiator has been bleed with the heater open. another thing if you go overboard with your coolant ratio forget it ever heating up before the 25min mark. I run race coolant in summer and min requirements in winter.
Making and running DUAL CHIPPED ECU SINCE 2010
Heater tap stuck closed or missing vacum line or thermostat is stuck open and letting the coolant flow too quick. (if not missing as said above)
and 3 Dangerous non ABS VN's
check that the heater tap is opening and closing when you turn the temperature dial from hot to cold etc. I did the coolant in a mates car yesterday and the heater tap wa snot moving with the temp control and I could not feel any vacuum on the hose when we took it off the heater tap. WTF is race coolant?
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
I know this is pretty stupid but,
try checking if your AC is on, that button has got me a few times![]()
thanks for all your help. lol na its not the ac button lol. and the heater switch and valve is working fine but i have a feeling its the thermostat because it seems like the engines running cold, takes ages for the temp to go up. il let yous not when i change the thermostat, shi*er of a job, any1 hav easy ways of doing it? sorry for my spelling, im used to txting on my phone lol.
Easy job mate. Before you start get a new thermostat and a thermostat housing gasket. To replace it just remove the two bolts holding the thermostat housing (where the top radiator hose joins the engine). The thermostat will be underneath.
my coolant has been flushed like that, car running bottom radiator hose off, garden hose in radiator filler - left for about 25 mins with heater on until water coming out was clear.
its a s1 engine so the thormostat is behind it,
and yeh il try that flush
Did you ended up finding a thermostat in the housing?If not,that could be the cause too.
i havnt done it yet. ive had no money and time
