Results 1 to 5 of 5
Thread: Instrument Connector #1 PITA
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Default Instrument Connector #1 PITA
    Howdy all
    Trying to install cruise control in the wagz and everything was smooth sailing until I came across Instrument Connector #1
    The wires don't seem to be long enough to get to the back of the connector and where it is placed there isn't anywhere to put a hand or anything through behind it
    Have pulled the centre console out to try and get some more length but the wires just aren't long enough
    Bloody annoying as it's just the one white wire to connect into the back of this and I'm done
    Anyone else have any hints or tips before I put it in the too hard basket for today ?
    If ignorance is bliss why aren't there more happy people around ?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The white and green wire are a lug into the back of the dash connectors.
    and 3 Dangerous non ABS VN's
    May 2006
    Yep, connector 3 was easy to clip the green wire into (plenty of wire length) but I can't even get #1 out far enough to remove the anti back out comb to take the lug that's in there out to put the white one in
    Is it possible the wires going to #1 are taped up with the loom and pulling some of the tape off will hopefully reveal enough wire to remove the comb and lug ?
    Tried to gently pull the wrapped loom through a bit but still not enough to be able to do anything
    88GreenVN's Avatar
    Jun 2006
    Your loom must be pinned some how. Normally you can pull enough wire through to get the pins out.
    How about going out the back of the dash? You would have most of the plastic bits out already to gain access to the plug.
    May 2006
    Aah, so just remove the orange surround and pull the plug back through (is it just the two clips on the sides or do I need to unclip the top and bottom as well) ?
    Cheers Shane, will try that Tuesday (won't get home from work till late tomorrow) and report back
    Thanks again !!
    EDIT.....
    Pulling it out the back worked a charm Shane, now just need to get a spare brake switch circlip from the wreckers and I'm all done
  1. where is the diagnostic connector
    By Corey walker in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-09-2009, 08:20 PM
  2. what's this connector?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2008, 08:30 PM
  3. VN Calais Connector
    By electro cruiser in forum Electrical Wiring / Questions
    Last Post: 01-03-2008, 01:45 PM
  4. Missing Connector
    By vn_calais in forum Car Audio
    Last Post: 07-02-2006, 02:27 AM
  5. So....where to get the OBDII connector in Oz
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2005, 12:20 PM
