Results 1 to 7 of 7
Thread: VP power steering pump leaking
    1992 VP Executive
    Jul 2009
    Default VP power steering pump leaking
    My VP power steering pump seems to be leaking.. I can't find any tutes on it here, other than replacing the whole pump.. I just want to repair it.
    If I buy a rebuild kit (like this), do I need a press?
    Someone mentioned that it's usually just the o-ring and I won't need a press to replace this.
    Cheers.
    92 VP Series 2
    Jan 2009
    East Brisbane
    nah dont need a press mate, and that guy is right, it is usually just an o-ring. very easy to do
    1992 VP Executive
    Jul 2009
    Thanks mate..
    Is the O-Ring at the front or the back? because it seems like it's leaking from the front.
    92 VP Series 2
    Jan 2009
    East Brisbane
    heres a thread i found which should help you out. on the 6th post 'azzfox' has posted up a pic that should help you too :
    Power steering pump - seal replacement
    1992 VP Executive
    Jul 2009
    Alright, have a look at the picture I've attached.. how do I remove the blue circled bit to fix the leak (indicated in red)?
    Here's the pic:
    http://img841.imageshack.us/img841/543/pspumpleak.png
    Attached Thumbnails Attached Thumbnails VP power steering pump leaking-pspump_leak.png
    calis vn v8
    Jan 2008
    found this reading other peoples threads - might help
    "Whoops forgot to report back, I did manage to remove the high pressure fitting. I took it to a mates place who has a propper vice but diddnt have a common metric socket to fit. We ended up breaking a shifter before realizing a 1inch socket fits perfectly. Managed to crack it with a breaker bar ".
    "For the shaft seal you firstly need to remove the shaft, and the only thing holding it on is a small circlip directly on the back of it (inside the pump). PITA to remove lol. But once thats off it should fall out. Then lever the old seal out with a screwdriver and install the new seal by tapping it in evenly with a soft hammer (or hammer and socket) until it sits flush to the opening."
    1992 VP Executive
    Jul 2009
    Got it all fixed, thanks guys..
    Boy that circlip was a bitch to get out!
  1. Leaking Power Steering Pump
    By scatterybrane_007 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 01:51 PM
  2. VR V6 Power Steering Pump Leaking
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2008, 12:42 PM
  3. VS power steer pump leaking
    By Kiwicommodore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 07:41 PM
  4. Help Power Steering Pump Leaking
    By hrtmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2008, 10:13 PM
  5. VN Power Steering Pump leaking
    By Muse7707 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 11:51 PM
