Yesteday i took my throtle body off my vn s2 v6 & completly striped it then cleaned it.
its all back together works great all the usual gaines drives normal still.
But the problem is that the check engine light comes on. NEED HELP PLEASE!!!![]()
try taking off a battery terminal for about 5 minutes and replacing, might help.
just tryed that it did'nt work. Some more ideas would be greatly appreceated.
after taking term off did you rev over 2000 for about 25 sec? if not try that
did that did nothing. Anymore guesses.
Im a true commy boy!!!
what is the codeOriginally Posted by I LIKE COMMODORES
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
What the F#$% does that mean?Originally Posted by burnz
Funny pic![]()
check for engine error codes.
Above the passenger footwell is a white electrical connector which you use to find error codes when the engine check light comes on.
Grab a paper clip and bridge pins number 5 & 6 the key till the ignition lights up.
If you bridged out the correct wires 'Check Engine Lamp' will be flashing and the engine fan should come on.
The flashes are grouped into 2 lots with roughly a second between each. You can decode them as follows:
The first lot of flashes is tens, eg if the 1st flash simply flashes once, this means the code is 10. After the pause of about a second, a 2nd lot of flashes will appear, if this number is 2, so the code is 12 which means everything is OK.
After each code sequence, the computer will repeat three times with about a 3 second pause between, so its smart to wait and see if you have numerous errors.
Illegitimi Non Carborundum
ill try that & get back 2 yaLL
What did u clean the throttle body with? Carbi clean is natourise for stuffing up idle stepper motors and map sensors![]()
i used a bit of petrol with an air hose and a stiff brush to clean the inside of mine out....the stepper motor doesnt get affected by the peterol
Ok so its a code 22-Throtle position sensor, voltage too low. How do i fox it
its all solved i just have to replace it & it fixed. Thanx 4 all the sugestions.
edit: must check full thread first![]()
