Results 1 to 8 of 8
Thread: Car won't start -
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default Car won't start -
    Currently on the side of the road as my cars stopped working less then 5 mins from home,
    It will start if I hole my foot lightly on the accelerator but if I take my foot off it cuts out. The fuel sender seems to be working fine but as it is almost 6 I doubt there is anywhere I can go to get something checked. Any ideas what my problem may be??
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Wild guess but stuck closed IAC? Dose it seem like the revs just wana stay to low?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    May 2010
    Croydon, Vic
    Yeah seems like they wanna stay pretty low or not build up to an idle speed
    May 2010
    Croydon, Vic
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    What I would do is if you got the screw to adjust the butterfly on the throttle body adjust it open a bit more. This could get you home if the IAC is the problem or just so you can get home!
    Im pretty sure it wouldnt start at all if it was the CAS, anyone confirm?
    The Daily VN T5V6
    355 VN GRP A REP
    May 2010
    Croydon, Vic
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    I duno, the cable ive never done it.
    If you think its the CAS try wedging somthing agaist it and try starting it.
    The Daily VN T5V6
    355 VN GRP A REP
    May 2010
    Croydon, Vic
    Just drove home with my foot on the accelerator all the time and done left foot braking, would a blocked/ stuffed iac valve most likely be the cause ??
  1. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  2. vs won't start
    By KE70GT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2008, 07:39 PM
  3. car won't start
    By veeteecommo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2008, 09:27 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
