Results 1 to 8 of 8
Thread: Code 12 but no spark help
    VN Executive
    Sep 2007
    Default Code 12 but no spark help
    Hey guys I have a VN series two I had been having trouble starting the car for a few weeks would finally kick 2nd or third times, It also began dying whilst I was driving it where the power was instantly lost the would stall.
    My ECU is giving a 12 code, I have check my leads and my spark plugs yet I have no spark?
    I checked the coil pack and it has the right ohms ect, also there appears to be power to the pack.
    Is this simply crank angle sensor or something or the like?
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    i had the same issue with the 5 speed wagon i brought a while back, and it was the crank angle sensor
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    VN Executive
    Sep 2007
    Thanks for your suggestion but I have replaced the crank angle sensor to no avail does anyone have any other ideas??
    VN Executive
    Sep 2007
    Mar 2010
    Whyalla SA
    ok, my bors vs had a the same problem and his turned out to be the the pins on the plug that connects to the coil pack had stretched apart a bit, so if you undo the 1 screw and remove the plug have a look and see if you can notice any stretched connection, if you do you can close them up a bit using something like a pin, also check for corrosion
    VH SS
    May 2009
    Toowoomba, Qld
    the DFI module (module under the coil pack) doesn't always throw a code when it fails
    But the process of elimination method can be rather expensive....
    the best way is to get someone to scan you the ignition system diagnostic flow chart from the GMH service manual and step your way through it. It might turn out that you have a bad connection somewhere or a break in a wire.
    VN Executive
    Sep 2007
    Thanks guys,
    I have a workshop manual and have gone through the steps of checking the coil pack resistance ect ect the last thing it says is try replacing the ignition module. I'm going to try one from the wreckers fingers crossed.
    I've checked the connections and the wires as best I can and haven't found an improvement
    Dec 2009
    while it's not the exact same car, someone in my street had a VT that would not start, it was towed to Holden and they couldn't fix it, in the end he replaced the motor. Turned out to be a broken/loose connection inside the DFI module or the connections from it to the coil packs.
  1. help with code 42 Electronic Spark Timing Circuit
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2010, 07:38 PM
  2. vu ss cuts out no spark or error code???
    By grn_goose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-06-2009, 07:58 PM
  3. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST)
    By red phase down in forum Electrical Wiring / Questions
    Last Post: 19-08-2006, 06:29 PM
  4. Code 42 - Electronic Spark Timing Bypass Circuit fault (EST
    By red phase down in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-07-2006, 12:00 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
