Results 1 to 5 of 5
Thread: Should the sway bar linkages have movement?
    VT V6, VP SII V6, 76 Mini SS
    Dec 2009
    Manjimup WA
    Default Should the sway bar linkages have movement?
    My cars steering wheel wobbles a little bit when driving so i had a look and the swaybar linkage rods (called stabiliser rods in the haynes book) seem to have decent amount of movement in them. I can visually see that the rubber bushes are cracked and perishing. I have order a replacement kit for both sides.
    Does anyone think that this would be the problem?
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Wheels off balance can cause sway bar links to work lose.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    VN Production Saloon
    Mar 2009
    Gisborne NZ
    Unlikely to be the wobble but worth doing anyway, just about every VN onwards Commodore front swaybar endlink i see till they went to jointed links is stuffed, OEM replacement rubber bushes outlast the polyuretahane aftermarket ones by a huge margin but having said that the nolathane 'z' link kits seem to work well
    COOK COUNTY PERFORMANCE porting heads/manifolds & blueprinting. tuning by DELCOWIZZID
    WANTED SV3800 headers for 34G, need stockers as made by HM headers ~ used with patina prefferable for scrutineering
    Dec 2009
    Manjimup WA
    What else can i check then? Ball joints?
    How do i check them? Jack the front end up and play around with a pry bar?
  1. VN sway bar> replace with VS sway bar?
    By GTP 85 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2009, 08:11 PM
  2. Active twin tech hat...where to get linkages/parts??
    By NOGEN 3 in forum V8 Development and Modification
    Last Post: 11-07-2009, 12:03 PM
  3. VH Quadrajet picture/linkages hoses etc
    By greenfoam in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-04-2009, 09:38 AM
  4. VS Manual V6 linkages
    By melawramenko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2008, 01:04 AM
  5. Transmission movement
    By Sebastian in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 11:51 PM
