I have a great VN S1 6 motor in a crap car, and can get a great S2 6 car with a dud motor.
The gearbox on the S1 is crap.
Will the S1 motor go straight in to the S2 car??
If so, this will save me a lot of money and trouble.
Thanks guys!
yes it will fit,
Matt
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
no, it will not fit. vn s1 has a different crankshaft to s2. done quite a bit of research into this because i was gonna to try a vn s1 engine in my vp. series one has a 6 bolt pattern (different also between manual and auto) and the series 2 is an 8 bolt pattern. if you want to change the engine, you'll need to change the transmission also. as for the wiring and computer, i didn't look that far into it but, it should be roughly the same.
Why do people reply that obviously have no idea?
V6 Crankshaft Info
If its auto you will be able to use either gearbox engine combo, but you need the right flex plate. A S1 6 bolt flex plate will bolt upto your S1 (if it is a auto motor) and you can then attach either series auto box to it. This is because the tourqe converter still has the same 3 bolts holding it to the flex plate both S1 and S2.
Computer wise your all good, no difference in a VN manual/auto.
You might also wana have a read of this,
The complete Vn-Vr Manual Conversion Guide.
The Daily VN T5V6
355 VN GRP A REP
hi guys i have a series 2 VN v6 motor.. and ive pulled the auto gearbox out.. the flywheel and torq convertor are together... now will a series 1 manual gearbox connect straight up to the VN v6 series 2.. If not what will i need to make it work
you need the 8 bolt flywheel if you have a flywheel from the series 1 engine it will be 6 bolt. ( the auto has a flexplate not a flywheel)
did you do the swap??
i have a series 2 engine, engine loom and ecu in my series one and it wont turn over. it tries. any wiring mods needed? any advice ???
also, a series 2 box WILL bolt onto a series 1. you just need the right flywheeli had a T5 vr box on my series one engine .
