Results 1 to 8 of 8
Thread: how to start my car without the key?
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    Default how to start my car without the key?
    I know it's frowned upon, but I need to somehow start my car without the key, as it appears to have snapped off in the ignition : and my spare is a few hundred kilometres away
    I remember reading on here a while ago about which wires to join up etc... If it's not too much to ask, can someone PM me that rather than chuck it up on the forum? Thanks, otherwise I'll i'll have to walk to the locksmiths etc...
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    So because the key is snapped off in the barrel the steering lock is disabled? If so the rest is pretty easy.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Starting your car is not the issue, driving it is! Once you take off, how are you going to turn the wheel when the steering locks?
    Grab a multimeter and find the active wire: Connect it to some of the other colours and see what turns on. Im not going to tell you exactly how to do it but its not hard once you get started.
    You should be able to drop the barrel switch off the back of the barrel and test the connection sequence using a multimeter also - that may give you a hint to the order you need to follow.
    How did you snap a commodore key off in a barrel though? And in such a manner you cant remove or turn it with multigrips?
    Quote Originally Posted by nstone63 View Post
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Put it in N.
    And stick a screwdriver between the terminals on the starter motor. Don't let it scare you when it goes zap, you'll be right. It'll start once the ignition is on.
    nstone63's Avatar
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    The key was already a bit screwed, so it didn't take much to break it off lol... theres a piece about 15mm long inside it because i thought "oh yeah, I'll just push the broken bit in all the way and try the key as well" - which screwed me up big time because i could have grabbed it with pliers before that
    the steering lock isn't on which is a bonus, so i'll have a fiddle with the wiring and go from there, thanks azkwazere
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    No need for a multimeter. PM sent.
    My (ex)Ride
    VR Commodore Executive
    Oct 2010
    There is a way it can be done, if you've got the time to do it. Take the Ignition Switch off the back of the Ignition Barrel, which is two tiny screws.. Don't lose them, you'll need them again later to put it back together lol.. once that switch is off, you can start the car with a screw driver. If the steering wheel is locked, you'll have to take the whole barrel apart, which is slightly more tricky.. since there isn't much room to get your allen key in, you can either cut one down to size..or tear a chuck out of your dash (which i did on my VN that i was wrecking, not advised in your case though lol) then simply take the steering lock out.. But remember how it all came apart, so you can put it back together when you get a new ignition barrel and key.
    nstone63's Avatar
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    all cool and sorted, thanks for the help.. I ended up doing it the was azzfox said in a PM.
    I got my spare keys posted down from Port Augusta, and everything's cool again lol
  1. Wouldn't start when warm, now won't start at all
    By karwalski in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2010, 06:18 PM
  2. Won't start...
    By snowybill in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2009, 05:48 PM
  3. Where to start
    By shach1971 in forum General
    Last Post: 01-11-2009, 06:21 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Can't start cold except for clutch start.
    By Holdfast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2005, 07:30 PM
