Results 1 to 9 of 9
Thread: How do i remove a Level 3 Cluster loom?
    L67 VS II Statesman (With a SunRoof ;)
    Mar 2010
    Whyalla SA
    Default How do i remove a Level 3 Cluster loom?
    hi all, im looking at doing a level 3 dash upgrade on my 88 VN T5 Wagon, but it dosent have the 4th plug, however ive got a loom in my other vn thats off to the wreckers, but i have no idea how to remove it :/, im also wondering about the power window loom, from the center console, behind the dash and into the fuse box, any help would be great
    Thanks
    Greg
    Officially In The SunRoof Crew
    '05 VZ Berlina September '09 - April '11
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Thr loom starts at the cruise control plug ang comes around the front of the car and back into the car via the fie wall on the drivers side. It then goes back around past the cluster/dash accrss to the ECU.
    and 3 Dangerous non ABS VN's
    Mar 2010
    Whyalla SA
    so ill be needing to remove the entire dash then, hehe this is gonna be fun :P
    Thanks,
    Greg
    88GreenVN's Avatar
    Jun 2006
    yep - dash out - not that much to it after the centre console is out. it's about 10 bolts tops.
    Mar 2010
    Whyalla SA
    wow thats no where near as bad as i was expecting
    88GreenVN's Avatar
    Jun 2006
    Once the side vents are off and the under dash trim bits - all of 10 mins work.
    The dash pad then only has 8 or so main bolts holding it in.
    Mar 2010
    Whyalla SA
    now worries mate, ill have a crack at it in the morning, thanks for your help
    crazyspoon05's Avatar
    crazyspoon05 is offline Penguin Whisperer
    The 'Bizta' VNVPVR Wagz
    May 2006
    Quote Originally Posted by 88GreenVN View Post
    Do you need to remove steering wheel/column or can you work around them (wouldn't mind pulling mine apart to find out why my loom is so tight near the dash area and install my power window/mirror, etc loom at the same time)
    If ignorance is bliss why aren't there more happy people around ?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by crazyspoon05 View Post
    You have to undo the bolts - I supported the column with a block of wood to the floor. The loom is pinned to the dash pad and there is enough room to look at the loom. You should be able to "reset" the loom to give you more lenght for the switchblock wires.
  1. [VIC] VR V6 Berlina Level 3 Cluster With Loom And Trip Control Panel
    By itchy123 in forum Parts And Other Items For Sale
    Last Post: 16-06-2010, 12:51 PM
  2. Will a level 3 dash be able to work on a level 1 loom?
    By dk4400 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-05-2010, 09:18 PM
  3. [SA] VR/VS Level 3 Dash Cluster Patch loom + trip Computer Swich
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 01-10-2009, 11:05 AM
  4. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  5. WTB: VR/VS Level 3 Instrument Cluster Loom
    By shaggerz in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2006, 11:56 AM
