Results 1 to 9 of 9
Thread: vn group a
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Question vn group a
    hey guys putting a group a kit on my vn but having a lil prob working out how the skirts go on it has the flat spot on it nd just dont no how it goes on all help it appreciated
    cheers guys
    VB SL/E
    Dec 2008
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    I'm actually doing this as we speak, same kit etc. First, you might think it wont fit over the bottom door sill if your slipping the bottom of the skirt under the car first. Best is to get a mate to hold the opposite side, slide the top into the door sill first, then bend the bottom under the bar, youll need something to hold it there while the urethane dries, and you won't have a lot of room for error so make sure your both happy with the positioning on your ends before leaving it to set.
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    Jan 2010
    So there arent any screws that hold it. The guy i got it from said that most of it sticks on with sikaflex will that hold the skirt or need something stronger. Im also wondering bout the 3 peice spoiler nd how the side parts of it go on and stay
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    sikaflex is retarded strong. holden use it for most the side trim panels on doors, if you've ever tried to remove one of those, you'll know that it'll handle the group a bits
    VB SL/E
    Dec 2008
    urethane = sikaflex
    Just get the right grade/type.
    alot of roofs and fire walls are held in with it these days.
    91 vn s
    Jun 2009
    Adelaide, SA
    sikaflex 227 if your wondering which type of sikaflex to use for bodywork
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    Quote Originally Posted by pow3rslave View Post
    unless im superman, if you can pry up one of the corners, a swift rip and it tears off very easily :/ done it to a VN, VP and VS and each were easy enough to remove.
    and yep, no screwing needed for the side skirts, but you may find you need to cut them as theyll be too short for the body of the car. Can i ask who you bought it off?
    Jan 2010
    i got it from a guy on the fourm he was selling it cheep and it just needed a little fix up nd just having trouble seein how it goes on lol
  1. Group A or Group 3 Body Kit
    By big_c_43 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-08-2009, 07:27 AM
  2. VN Group A SS ECU.....
    By VNCPTR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2009, 10:54 PM
  3. F/S [SA] VL Group A Bonnet Scoop (Sell or swap for VN Group A scoop)
    By STEALTHY™ in forum Parts And Other Items For Sale
    Last Post: 09-03-2008, 10:03 PM
  4. Fs Vn Group A Kit
    By SthEastCustoms in forum Parts And Other Items For Sale
    Last Post: 03-03-2007, 09:43 AM
  5. vk ss group a kit
    By pier_one in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-01-2006, 10:15 AM
