Results 1 to 3 of 3
Thread: v8 308 engine
    none
    Sep 2009
    Perth Wa
    Default v8 308 engine
    hows it going. i own a vp commodore ute 1992 or 93 one of them anyway. its a 5 speed manual v6. the only mods ive done to it so far is a full exhaust system straight through single muffler berklee exhaust, no extractors yet just standard and catalytic converter standard. for christmas i was going to treat myself to a brand new 308 v8 chromed. is it possible to stick it in my ute with all the right stuff? thanks.
    Feb 2008
    should be possible, but you will need a different gearbox and i think engine mounts and like the bottles an stuff in your engine for coolant and windscreen washers an all that.
    Ossama Bin Laden >>>>>>>>>>> Hide n' Seek Champ since 2001
    VP Berlina LX wagon 5.0L M5
    Dec 2005
    i doubt you'd be able to legally register it with an old 308. you'd need an injected VN onwards 304 for it to be legal. you can't put an older type engine in a newer car. as for fitting a 308, yes it'd fit (same as fitting a later 304). you'll need a V8 k-frame, engine mounts, etc. hope that helps.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Can i have my VZ V6 175 kw engine changed for a same model type 190 kw engine
    By aquatribal in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-07-2010, 02:13 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
