Results 1 to 13 of 13
Thread: 2 simple questions?
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    Exclamation 2 simple questions?
    Hi,
    2 questions.
    1: How the hell do I jack my car now that I have side skirts on? i really don't think the fibreglass will take the weight of the car and there isnt anywhere i can place the jack where i would have before that isnt fibreglass now.
    2: I have some ultra long threads through the reo to bolt on the bumper, and i cant fit a spanner over that let alone fit pliers in to undo it and its too tight to undo by hand.
    Really f***ing pissed off nobody thinks of these things and now im stuck with a punctured tyre that cant be changed and irremovable nuts.
    All I can think is remove the sideskirts and cut out 2 squares of it on the bottom at the front and rear, but id rather not remove them now as theyve been urethaned on.
    As for the nut on the ridiculously long thread, God knows, maybe remove the headlight but dads being an asswipe and wont tell me how to remove it because he doesnt think i should play around with it and will probably kill me if i try.
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    For the first one, just find a solid looking bit of steel under the body of the car. Dont lift it by the floor pan or fuel tank or you will dent it. If you want to lift it by the diff, be careful of your brake lines
    CAn you post a pic of these threads on the reo bar? I cant think of what it might be, and its been a long time since I changed a front bumper.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    Front tyre is punctured and I cant think of anything to jack it from :|
    its an aftermarket bar, basically the threads go thru the reo whcih are fibreglassed to my bumper, and im trying to undo these nuts, and the threads about 5cm long. Dad reckons a box spanner, but he doesnt understand theres such limited room under there, i can barely get my hand in, let alone a spanner. Doesn't help the tyre is flat on the side the nut needs to be removed and that the bumper is maybe sitting 7cm off the ground as it is.
    The one on the opposite side was a little loose so i got it off just using my fingers and spinning it a trillion times to get it off those ridiculous threads.
    Thanks for your help though
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    you could take the reo off the chassis rails. to bolts on each sides. can be a bitch to get it lined up when it goes back on.
    jacking it up, you could use the diff centre at the back, or the k frame (BUT NOT THE SUMP) at the front.
    this assumes you have a trolley jack, it'd be lots easier than using the crank jack that the car came wtih.
    walking
    Feb 2009
    Northern beachesNSW
    k frame or just underneath the ball joint there is something where you can do it
    Quote Originally Posted by rolyvan View Post
    Hi; Just bought vc commy; and the lion on the dashboard keeps flashing on and off, it sometimes stays constantly on, I have no idea what it means
    Quote Originally Posted by ari666 View Post
    your supposed to roar when it comes on.
    it comes on so much of lost my voice
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    If i could get under the car, id undo the bolts from the chassis rails to take off the reo (which is why im getting to bumper off, to raise the reo slightly and to cut the flaps off the sides of the bumper) but due to the flat tyre, the car has such small ground clearance its a bitch even getting my arms under.
    and I only have a crank jack
    Jan 2008
    Try a tube socket?
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    have u got the head lights out? makes the job alot easier gettin them screws in
    ________________________________________
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    isnt a tube wrench the same as a box spanner?
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Get a trolley jack and it sounds like all your probs will be solved, those shitty jacks that come in the car are useless, slow and pretty dam unstable
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    yeah next on my list.
    Took the headlight out, the threads are a bit crap and jammed the nut so it was difficult to get off even with the headlight out. Will put the bar back on tomorrow and hopefully that damn gap will be gone
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    itf the car is movable try driving the wheels over a brick while u tempoarily jack it up... ?
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  1. I need help, very simple...
    By ryanrandall in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-08-2010, 09:23 PM
  2. steering/suspension components - simple questions for you
    By javt99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2008, 05:24 PM
  3. just a few simple questions
    By garfa in forum Car Audio
    Last Post: 04-09-2006, 05:24 PM
  4. A few simple questions
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 10:33 PM
  5. couple of simple questions
    By gocommygo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 05:40 PM
