D
dualgas
Guest
I am having a problem whereby there is no power getting to my fuel pump. The relay and fuse are fine, but I have noticed when using a multimeter after taking the relay off that power is only coming to the 'power in' wire. The 'switch' and 'power out acc 1' do not have any voltage ? I have taken off the door trim and the thick purple wire (fuel pump); this is where there should be power but I am getting none.
Does anyone have a schematic of this or have they experienced a similar problem ?
