is it possible to install a vy/vz steering wheel to a vp ?
thanks guys
Pretty sure the inside bit is different, you'd have to make up a custom steering wheel and put the trims on it
no, a VY steering wheel won't fit a VP. VT onwards steering wheels have a thicker diameter spline where it fits up. a VS wheel will fit a VP, however there will be a gap between the plastic column shroud and the wheel. not sure if the indicator cancel works or not.
thanks guys![]()
