Results 1 to 12 of 12
Thread: runs rough in drive
    vn Executive
    Sep 2010
    Default runs rough in drive
    when i select drive when the cars running with the brake on it runs realy rough on idol, hole car shakes,
    if you guys have any ideas what it could be, let me no
    thanks
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Do you mean the whole car shakes when idling in drive with the foot on the brakes? Not meaning to sound like a smart arse just clarifying your comments.
    Illegitimi Non Carborundum
    vn Executive
    Sep 2010
    VP Commodore
    Feb 2008
    Leda, WA
    i had a vs that did that... got told it was the engine mounts.... but it did it in neutral and park too....
    philip_rawoz@yahoo.com.au
    RawOz Photography, specialising in nature and motorsports.
    vn Executive
    Sep 2010
    update,
    i did a fault test with the paper clip i got code 13, so thats that oxy senser, i reset the ecu and its running smooth now and the fault code still hasnt come back up,
    should i replace the oxy sensor still?
    91 vn s
    Jun 2009
    Adelaide, SA
    yes. the oxy sensor is probably giving false reading now anyway. i had to replace mine a while ago
    Dec 2009
    I bought a genuine O2 sensor from my local Holden dealer for around $50 a few years ago. Other than that check your spark plug lead resistance and if it's too high get some new ones. Also have a look and check they have no corrosion on the ends and how old are the spark plugs?
    VP Commodore
    Feb 2008
    Leda, WA
    Quote Originally Posted by vncomo View Post
    update,
    fault test with the paper clip??
    Dec 2009
    Quote Originally Posted by pipzryd View Post
    You bridge out 2 pins on a socket in the wiring harness and turn the ignition on and the engine light will flash indicating which error codes are logged.
    VP Commodore
    Feb 2008
    Leda, WA
    vs commodore
    Oct 2009
    Tamworth NSW
    Does the engine only start to run rough when its idling in gear and the brake pedal is pressed?If so,Id say you could have a leaking brake booster diaphram,which can cause air so be sucked straight into the engine via the vacuum lines when the brake pedal is pressed,which is why it upsets how the engine idles and runs, this is because the IAC (Idle Air Control )valve,which controls the idle speed etc, cant properly regulate the amount of air going into the engine...
    vn Executive
    Sep 2010
    i just did A full servise, and cleaned the throttel body, im goin to buy a o2 sensor, it seems to be running good now but still abit rough, il have have a look at the brakebooster tomorow
  1. VN v8 runs rough
    By rmkaris in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-05-2010, 04:26 PM
  2. runs rough runs smooth runs rough runs smooth
    By BobbyWatson in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2009, 08:48 PM
  3. Vs runs rough
    By HK-VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-10-2008, 11:11 AM
  4. Runs rough enough to shake car
    By Insanesinner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-01-2006, 07:30 PM
  5. runs rough at start
    By jjamor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2005, 10:48 PM
