Results 1 to 7 of 7
Thread: boot release on alarm
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Default boot release on alarm
    hey Ive had a uniden alarm in my car for ages, got it installed when i bought it. Just noticed that the remote has a boot release button. Was thinking I could wire it up to the boot release.
    To do this I assume I can just tap into the wires going to the button in the glovebox and then connect to the alarm box thing? It makes sense in my head but thought id check
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    If all the cables coming from the alarm are black good luck finding the one for the boot release.
    Anless the wire was left and marked its going to be pretty hard to do without a new loom for the alarm.
    If you do find it, it will proberly be a switched earth. I ran that cable to my boot and taped into 12v, to the solenoid then to the switch earth of the alarm. But I done this cause i didnt have a boot release to start off with. Im sure you can tap in at the button in the glove box.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    lemusa's Avatar
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Is it normal for all the wires from the alarm to be black? I havent actually had a look at the box. Guess I could use a multimeter and see which wire livens up when i hit the boot release on the remote
    turmoil117's Avatar
    turmoil117 is offline Donating Member
    vn berlina, vr statesman
    Jan 2010
    Westminster
    For the one in my vn I had to run the alarm wire into a relay then from the relay I spliced into the wire going to the boot for the release
    lemusa's Avatar
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    whats the relay for? Il have a look in the weekend if i get the chance and see whats on the alarm box
    turmoil117's Avatar
    Jan 2010
    Westminster
    The wire coming from the immobilizer was negatative and the boot release operated with a positive signal so I used a relay to do that.
    lemusa's Avatar
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Cheers mate, not the flashest with electrics so il let you know if i run into probs
  1. Boot release broken, How do I open the boot to fix it?
    By CraigAB in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-10-2010, 08:54 PM
  2. Boot Release
    By VP Pursuit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2008, 08:18 PM
  3. Alarm and boot release help!!
    By GIMPY1 in forum Electrical Wiring / Questions
    Last Post: 13-01-2008, 10:58 AM
  4. Boot Release
    By magooly in forum Electrical Wiring / Questions
    Last Post: 14-04-2006, 05:56 PM
  5. Boot Release not Releasing Boot
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2005, 07:30 PM
