so ive always had squeaky brakes but in the past few weeks it has gotten alot worse so i decided to check out all my rotors and pads. everything seemed good except my front rotors which i wasnt sure about. i measured the thickness and i got 23mm on the left side and 22mm on the right side. should i be replacing these soon or should there still be some life left in them? thanks for any inputp.s. its a vp v6 auto without irs or abs or anything fancy lol
21mm min there are two different rotors for the vp v6
this is out of the ac delco book for the change over http://www.acdelco.com.au/PDFs/Catal...lco_Rotors.pdf
VP NON-ABS, TO L569902 V6 (271mm ROTOR) 10/1991 - 05/1992 FRONT ACDR015 Vented
NON-ABS, FROM L569903 V6, 14" WHEEL (271mm ROTOR) 05/1992 - 09/1992 FRONT ACDR025 Vented
NON-ABS, TO L570556 V8 (289mm ROTOR) 10/1991 - 05/1992 FRONT ACDR017 Vented
ABS, NON-ABS, FROM L570557 V8, V6, 15" (289mm ROTOR) 05/1992 - 07/1993 FRONT ACDR027 Vented
W/O IRS 10/1991 - 07/1993 REAR ACDR016 Solid
IRS 10/1991 - 07/1993 REAR ACDR026 Solid
sweet as thanks heaps mate. any chance does anyone know how long front rotors should last? ive had these on for about 40,000 kms and i do a fair bit of city driving in stop-start traffic, is that any good or should i be expecting better? cheers
cheers mate, yer they were a fairly cheap set so i think im pretty happy with how long they've lasted
Just use soft pads, my rotors have some wear as well but used to squeak and make all sorts of noises with hard pads.
