Hey all
Ive got a VP sedan, If i just buy VT calipers, and worry about the rotors later, will they bolt straight up and be fine with the front rotors??
VKC
well techinically they will bolt up fine... as such dunno how they would sit over the rotor tho..... ... but they use the same 2 large bolts at the back to bolt on
pads hang over the edge of vp discs not a good idea
plus Vp rotors are way under the min size of a VT disc even when they are new, you risk popping the piston out of the caliper and losing the brakes.
Ok. Thanks. I'll get rotors then.
You have to buy adapter hubs to fit the rotors as VT are a floating rotor and separate hub where as vb-vp are all the style with the rotor also containing the bearing as 1 assembly. Also you really should upgrade your master cylinder if you do this conversion, reasons why have been covered a thousand times.
Serious man? Sounds like too much trouble for now, I might just hold off and get my VE kit
Your VE kit, get away from my shed!
The Daily VN T5V6
355 VN GRP A REP
Ill happily take your VE kit, But i need a v6 one for my chasers
If you do can we convert your lower part of the strut to a VR/VS one?
The Daily VN T5V6
355 VN GRP A REP
Whats the point of that?
