Results 1 to 4 of 4
Thread: vp commodore intermittent lights dim
    blaikey is offline blaikey
    vp commodore exec S2
    Oct 2010
    gympie queensland
    Default vp commodore intermittent lights dim
    While driving my vp the other night i noticed my headlights are dimming a little for about a second and and while idling the revs are dropping a little at the same time. This happens about every 10 seconds, there are no warning lights coming on so i don't think it is the alternator. also happens with the engine off and key turned to on.I can't for the life of me figure it out, any ideas?
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive seen something similar before and tracked it down to the main power wire that goes from the positive battery terminal to the main 60A fusible link.Just below the fusible link holder is a little black plastic door that opens out,behind this theres a bolt that goes through the wire connector and the main fusible link.(the bolt also holds the main 60A fusible link in place).This wire connector was corroded and loose.To me, it looked like the battery moving around in the battery tray moved the wire enough over time to cause it to loosen and then corrode where it was crimped to the connector.I just rejoined the wire to a new connector and it has been all good since.It might not be what your problem is,but its definitely worth a look.Especially if the battery is a bit loose in its tray and there are no other obvious signs of anything wrong.
    Oct 2010
    gympie queensland
    thanks for the input brett but 1 don't think that is the problem, forgot to mention that it also happens with the engine off a key tured to on.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by blaikey View Post
    Well I doubt its going to be the problem then,but if the join is corroded at all,and theres high resistance there, it could cause it to happen with the car not running.Id still have a quick look anyway.
  1. Vs Commodore Intermittent Starting
    By wabbit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-05-2011, 07:37 PM
  2. VR Commodore garnish lights and number plate lights not working...
    By cody84 in forum Electrical Wiring / Questions
    Last Post: 23-09-2009, 07:41 PM
  3. DIY led vs commodore lights?
    By axemurderer101 in forum Electrical Wiring / Questions
    Last Post: 27-02-2009, 05:57 PM
  4. Intermittent Stall ( '97 VSII Commodore)
    By teamkiller in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 03:02 PM
  5. Intermittent Lights Calais-VT
    By bahfenf in forum General
    Last Post: 18-10-2006, 03:04 PM
