Results 1 to 5 of 5
Thread: new engine for vn
    crofty77 is offline crofty
    vn series 1 s pack 3.8lt
    Jun 2010
    warrnambool, victoria
    Default new engine for vn
    hey guys this is probably a stupid question but im just wondering if its possible to put a vt engine in my vn with out to much cost and expence involved
    cheers
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    It isn't too much of a big deal if you have a donor vehicle and can swap everything out. Apart from the body control module, but you can get a memcal that will fix that.
    Warranty Void
    Jun 2010
    righto is it at all possible for the vt engine to go onto my t5 gearbox from the vn engine?
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Quote Originally Posted by crofty77 View Post
    Probably not, if its an S1 VN. I think you have to have a 30mm or so spacer made up for the flywheel as the crank on the s1vn is 30mm longer. Might be 30mm shorter though, I cant remember exactly.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    if you can find a t5 ecotec flywheel then yes. good luck finding one though
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Upper Engine Cleaning on old Engine (Unopened)
    By Jesterarts in forum The Pub
    Last Post: 17-02-2010, 09:02 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
